Hey everyone! I wanted to share my recent success in integrating Somfy motors with my SmartThings setup. It’s been a journey, but I’m thrilled to finally have seamless control over my blinds and curtains through the SmartThings app. Here’s how I did it and some tips for anyone looking to do the same!
The Challenge
I’ve always been a fan of Somfy motors for their reliability and quiet operation. However, getting them to work with SmartThings wasn’t straightforward. After some research, I discovered that Somfy motors aren’t natively supported by SmartThings, which was a bit discouraging. But I wasn’t ready to give up just yet!
The Solution
After digging through forums and tutorials, I stumbled upon a clever workaround using Linear relays. The idea is to use the relays to simulate button presses on the Somfy remote, effectively controlling the motors through SmartThings. Here’s a breakdown of what I did:
Materials Needed
- Somfy motor and remote
- Linear Z-Wave relay(s)
- Soldering kit
- Project box
The Setup
- I carefully disassembled the Somfy remote to identify the contacts corresponding to each button (up, down, stop).
- Using the soldering kit, I connected these contacts to the Linear relays. Each relay corresponds to a specific function (e.g., one for up, one for down).
- I housed everything neatly in a project box to keep it organized and safe.
Integration with SmartThings
- I added the Linear relays to my SmartThings hub. Each relay was configured as a separate switch in the SmartThings app.
- I created simple automations in SmartThings to trigger the relays when I press the corresponding buttons in the app. For example, pressing “Up” in the app sends a signal to the relay, which then simulates a button press on the Somfy remote, causing the blind to rise.
Tips for Success
- Label Everything Clearly: Before disassembling the remote, label each wire and contact to avoid confusion during reassembly.
- Test Each Connection: After soldering, test each connection individually to ensure they’re working before integrating them into the SmartThings setup.
- Use Quality Components: Invest in good-quality relays and wiring to ensure reliability and longevity.
The Outcome
The result? Seamless control over my Somfy motors directly from my smartphone! It’s incredibly satisfying to watch my blinds rise and fall with just a tap on my screen. Plus, I can now integrate these controls into more complex automations, like having my blinds close automatically at sunset or open when I wake up in the morning.
While this project required some DIY skills and patience, it was well worth the effort. It’s a fantastic way to bring older, non-smart devices into the smart home ecosystem without breaking the bank. If you’re looking to do something similar, I highly recommend giving this method a try!
A huge thank you to the SmartThings community for all the invaluable resources and support. Here’s to many more smart home projects!
Cheers,
