Hi everyone, I recently decided to integrate my Sonoff Mini with my Hubitat Hub, and I thought I’d share my experience in case anyone else is looking to do the same. This process was a bit of a learning curve for me, but I managed to get everything working smoothly. Here’s how I did it:
Step 1: Gathering the Necessary Tools
Before diving into the setup, make sure you have everything you need. I used the following:
- Sonoff Mini: My smart switch of choice.
- Hubitat Hub: The central hub for my smart home ecosystem.
- ** Smartphone**: For the initial setup and configuration.
- ** Screws and Screwdriver**: To mount the Sonoff Mini if needed.
Step 2: Preparing the Sonoff Mini
- Unboxing and Initial Setup: Start by unboxing your Sonoff Mini and attaching the necessary components. I found it helpful to watch a quick video tutorial to ensure I was assembling everything correctly.
- Connecting to Wi-Fi: Use the Sonoff app to connect the device to your home Wi-Fi. This step is crucial as it allows the Sonoff Mini to communicate with your Hubitat Hub.
Step 3: Pairing with Hubitat Hub
- Adding the Device: Open the Hubitat app and navigate to the ‘Devices’ section. Tap on ‘Add Device’ and select ‘Zigbee’ as the protocol. Follow the on-screen instructions to put your Sonoff Mini into pairing mode. I had to press and hold the reset button for about 5 seconds until the LED started flashing.
- Verification: Once paired, the Sonoff Mini should appear in your list of devices. I did a quick test by turning the connected light on and off through the app to ensure everything was working.
Step 4: Customizing the Setup
- Assigning a Room: I assigned the Sonoff Mini to the ‘Living Room’ to keep things organized. This helps in quickly accessing the device when needed.
- Setting Up Scenes: To enhance my smart home experience, I created a scene where the Sonoff Mini turns on the living room lights at sunset. This was done through the Hubitat app’s automation feature.
Step 5: Testing and Troubleshooting
After setting everything up, I spent some time testing the device under different conditions. Here are a few tips I picked up along the way:
- Firmware Updates: Ensure your Sonoff Mini and Hubitat Hub are running the latest firmware. This can usually be done through the respective apps.
- Signal Strength: If you experience any lag or unresponsiveness, check the placement of your Sonoff Mini to ensure it has a strong signal with the Hubitat Hub.
Integrating the Sonoff Mini with my Hubitat Hub has been a fantastic addition to my smart home setup. The ability to control my lights remotely and set up automated scenes has made my life much more convenient. If you’re considering this integration, I highly recommend giving it a try!
Let me know if you have any questions or if you’d like more details on any of the steps. Happy smart home building! ![]()
