I recently embarked on a journey to integrate my Sonoff 4Ch Pro with Tasmota firmware into Home Assistant (HA). Initially, everything went smoothly—I set up the device using setoption19 1, and the entities appeared in HA. However, as I experimented with renaming the channels, I encountered a puzzling issue where the renamed entities wouldn’t reflect in HA despite multiple reboots and restarts.
Determined to resolve this, I decided to start fresh. I deleted the existing entities, uninstalled the HA integration, and even reinstalled MQTT. After reconfiguring the Sonoff, I was hopeful the channels would reappear. Unfortunately, they didn’t.
I reached out to the community for advice, and through some troubleshooting, I realized that the issue might be related to retained MQTT messages from previous configurations. After some research, I discovered that clearing the MQTT broker’s retained messages could resolve the problem.
Here’s what I did:
- I restarted my MQTT broker to ensure all retained messages were cleared.
- I performed a factory reset on the Sonoff to remove any lingering configurations.
- I reinstalled the Tasmota firmware and reapplied the desired channel names.
- I reconfigured the integration in HA, carefully following the setup steps.
To my delight, the channels reappeared in HA, and everything functioned as intended! This experience taught me the importance of understanding MQTT’s behavior and the value of persistence in troubleshooting.
If anyone else is facing similar issues, I recommend checking for retained messages and ensuring a clean slate before reconfiguring. Happy integrating everyone! ![]()
