Successfully Integrating Wyze Floodlight Pro with Wyze Sense Hub
Hey everyone, I wanted to share my experience integrating the Wyze Floodlight Pro cameras with the Wyze Sense Hub. Initially, I was a bit concerned because my older cameras showed up in the list, but the Floodlight Pros didn’t. I was worried they might not be compatible, especially since they’re integral to my home security setup, monitoring both my yard and entry doors.
After some research and trial and error, I found that the key was ensuring the firmware on both the Floodlight Pros and the Sense Hub was up to date. Once that was done, I manually paired each camera through the Wyze app, which involved going into the settings and selecting the option to add a new device. It took a bit of patience, but they finally connected!
Now, they work seamlessly with the Sense Hub, and I can monitor everything from the app. It’s such a relief to have everything integrated smoothly. If anyone else is having trouble, I’d recommend checking firmware updates first and then trying a manual pairing. Happy smart home integrating! :star2:
