Successfully Migrating from Wired to Surety Security System
After years of relying on a traditional wired security system installed by Brink, I decided it was time for an upgrade. The allure of a modern, wireless setup with Surety was undeniable, but the transition wasn’t without its hurdles. Here’s my journey and some tips for anyone considering a similar move.
The Setup
I started with the central panel and wired sensors from my old system. The first step was understanding what could be repurposed and what needed replacing. Surety’s compatibility with existing hardware was a huge plus, but I quickly realized not all components would seamlessly integrate.
Challenges Faced
  1. Sensor Compatibility: Not all my wired sensors were compatible with Surety. I had to research which models were supported and which needed upgrading. This process took some time, but Surety’s support team was incredibly helpful.
  2. Configuration: Setting up the new system required a steep learning curve. The Surety app is user-friendly, but customizing it to match my old system’s functionality took patience.
  3. Testing: Ensuring every sensor worked post-installation was crucial. I recommend testing each component individually before declaring the system fully operational.
Tips for a Smooth Transition
  • Plan Ahead: Make a list of all your current sensors and check their compatibility with Surety beforehand.
  • Backup Power: Invest in reliable backup batteries for your sensors to avoid any downtime.
  • Professional Help: If you’re unsure about any part of the process, consider hiring a professional installer. It’s worth the investment for peace of mind.
The Outcome
Now, I enjoy a sleek, wireless security system that’s easier to manage and more adaptable to my changing needs. The Surety app provides real-time monitoring, and the integration with my smart home devices has taken my security to the next level.
If you’re contemplating an upgrade, I highly recommend exploring Surety. The initial setup might seem daunting, but the benefits far outweigh the effort. Happy upgrading!
