Successfully Migrating Z-Wave Devices to a New Hub
I recently embarked on a project to migrate my Z-Wave devices from an older Nortec (Go-Control) HUSBZB-1 hub to a new Zooz 800 Z-Wave stick. My goal was to phase out the old hub while maintaining the functionality of all my devices. Here’s my journey and the lessons I learned along the way.
Initially, I faced some challenges. When I tried adding the Zooz 800 stick to my Home Assistant setup, the Z-Wave JS add-on failed to start. I retried multiple times, each time encountering the same error. I even disabled the old hub temporarily to see if it was causing interference, but the issue persisted. Frustration set in as I couldn’t find a clear solution in the documentation.
After some research and digging through logs, I discovered that the problem might be related to the add-on configuration. I decided to completely remove the old hub and all associated entities from my setup. This was a daunting task, but I knew it was necessary to start fresh. I meticulously re-added each of my 50+ Z-Wave devices one by one, ensuring a smooth transition without disrupting my daily routine.
The process taught me the importance of patience and thorough planning. I also learned that sometimes, starting over can be the most efficient way to resolve complex issues. Now, with everything up and running on the new Zooz 800, I’m confident that my Z-Wave network is more reliable and future-proof.
If you’re considering a similar migration, here are a few tips:
  • Backup your configuration: Before making any changes, ensure you have a complete backup of your current setup.
  • Gradual migration: Instead of replacing everything at once, migrate devices gradually to minimize downtime.
  • Check logs: If you encounter issues, the logs are your best friend. They often provide clues that aren’t immediately obvious.
  • Community support: Don’t hesitate to reach out to forums and communities. Sometimes, a fresh pair of eyes can spot the solution quickly.
This experience has been both challenging and rewarding. It reinforced my appreciation for the flexibility and power of Home Assistant, and it gave me a deeper understanding of Z-Wave networks. I’m now more confident in troubleshooting and optimizing my smart home setup.
