Successfully Mounting NAS in OpenHAB: My Experience
After struggling with NAS mounting issues in OpenHAB, I’m thrilled to share my successful experience. Initially, I faced challenges where the NAS wouldn’t mount after a reboot, disrupting my backup system. Here’s how I resolved it:
  1. Identify the Problem: The NAS wasn’t mounting consistently, especially after reboots. I noticed this issue after switching to a Raspberry Pi 3 Model B Plus with an SSD.
  2. Research Solutions: I explored various forums and discovered that running mount -a manually could temporarily fix the issue. However, I wanted a more permanent solution.
  3. Modify Boot Configuration: I added rootwait to the cmdline.txt file to ensure the SSD was fully initialized before booting. This adjustment helped stabilize the mounting process.
  4. Adjust Mount Order: By tweaking the order of mounts in /etc/fstab, I ensured the NAS mounted after critical system components. This prevented conflicts during boot.
  5. Test and Verify: After implementing these changes, I rebooted the system multiple times to confirm the NAS mounted successfully each time. The backup system now runs smoothly without manual intervention.
Tips for Others:
  • Always check boot logs for mounting errors using journalctl -u systemd-mount.- Consider SSD-specific boot parameters if using an SSD.- Regularly test backups to ensure everything works as expected.
This resolution not only saved me time but also gave me confidence in my OpenHAB setup. I hope this helps others facing similar challenges!
