Hello everyone, I wanted to share my recent experience with upgrading Home Assistant and how I managed to resolve some issues that arose during the process. It was a bit of a rollercoaster, but I learned a lot along the way!
Earlier this week, I decided to upgrade my Home Assistant instance to the latest version, 2023.11. Everything seemed to be going smoothly at first, but after the update, I noticed that the system became unresponsive. Both the IP and Web UI were inaccessible, which was quite concerning. I checked the network interface on my switch and saw that while the link was up and the protocol was active, there was no outgoing traffic from my Raspberry Pi. It was as if the device had completely frozen.
I started by reviewing the logs and noticed some errors related to disk space. The system was reporting an ‘out of disk space’ issue, which I hadn’t anticipated. My Raspberry Pi was running on a 64GB SD card, which I assumed was more than sufficient. However, it turned out that the update had caused the storage to become full, preventing the system from functioning properly.
My first step was to try and manually assign an IP address through the command line, using the net update command. Unfortunately, this didn’t work as expected, and I received an error message stating that the file couldn’t be written due to the lack of available disk space. This was a clear indication that the storage issue was the root cause of the problem.
I decided to take a proactive approach and image the original SD card, transferring the image to a larger 256GB SD card. I hoped that by doing this, the system would automatically expand the volumes and resolve the disk space issue. After booting up with the new SD card, the system seemed to stabilize, but the problem persisted. I then proceeded to delete some old backup files using the command line, which freed up some space, but it still wasn’t enough to fully resolve the issue.
I also checked for any pending update tasks or jobs, refreshed the update repositories, and ensured that everything was up to date. Despite these efforts, the system remained unresponsive. It was at this point that I realized the extent of the storage problem and the need for a more comprehensive solution.
After some research, I came across a suggestion to use a larger SD card and ensure that the file system was properly expanded. I decided to give this a try and was pleasantly surprised when it worked. By expanding the file system on the new 256GB SD card, I was able to free up enough space for the system to operate normally again. The upgrade process was completed without further issues, and I was able to access my Home Assistant instance once more.
This experience taught me the importance of monitoring disk space and ensuring that there is always enough available storage, especially when performing system updates. It also highlighted the value of having a reliable backup strategy and the necessity of testing backups regularly to ensure they can be restored when needed.
I would like to thank the Home Assistant community for their invaluable support and resources. Without the guidance and troubleshooting tips shared by others, I might not have been able to resolve this issue as efficiently as I did. It’s a testament to the strength of the community and the collaborative spirit that makes projects like Home Assistant so successful.
In conclusion, while upgrading can sometimes lead to unexpected challenges, with persistence and the right approach, it’s possible to overcome them. I hope my experience can serve as a helpful reference for anyone else facing similar issues in the future. Happy automating everyone! ![]()
