Successfully Resolving Zigbee Connectivity Issues with Skyconnect Stick
Hi everyone,
I wanted to share my recent experience with resolving a Zigbee connectivity issue that had been quite frustrating. After struggling for several weeks, I finally found a solution that seems to be working consistently.
For those who might not know, I’ve been using Zigbee devices in my smart home setup, and everything was working smoothly until recently. Suddenly, my devices started disconnecting frequently, especially after certain automations or actions were triggered. This disrupted my routines, and I was at a loss for how to fix it.
I tried a variety of troubleshooting steps:
  • Resetting the Zigbee network: This temporarily fixed the issue but didn’t resolve the underlying problem.
  • Updating firmware: I made sure all my devices were on the latest firmware versions, but that didn’t help either.
  • Checking for interference: I moved the coordinator to different locations to minimize potential RF interference, but the problem persisted.
  • Reinstalling software: I uninstalled and reinstalled my Zigbee software, but the issue remained.
After several days of trial and error, I came across a suggestion in another forum about disabling the Watchdog feature on my Skyconnect Stick. Initially, I wasn’t sure what this meant, but I decided to give it a shot.
Here’s what I did:
  1. I accessed the settings for my Skyconnect Stick in my Zigbee controller.
  2. I found the option to disable the Watchdog timer.
  3. After disabling it, I restarted my Zigbee network.
To my delight, my devices connected immediately and have remained stable ever since! I’m not entirely sure why the Watchdog was causing issues, but I’m just happy it’s fixed.
I wanted to share this in case someone else is experiencing similar problems. Sometimes, the solution is a simple setting change that you might not think to try. I hope this helps someone avoid the frustration I went through!
Cheers,
