Successfully Separating Sonoff TX Switches in Home Assistant
Hi everyone, I hope this post finds you all well! I wanted to share my recent experience with configuring Sonoff TX switches in Home Assistant. While I’m still new to this, I’ve learned a lot and thought I’d pass along what I discovered in case it helps someone else.
When I first set up my Sonoff TX switches, I noticed that Home Assistant grouped all the switches together in the same room, which wasn’t exactly what I wanted. After doing a bit of research and experimenting, I found a solution that worked perfectly for my setup.
Here’s what I did:
  1. Understanding the Configuration: I realized that the initial setup grouped all switches based on the room I assigned during configuration. To separate them, I needed to adjust the entity configuration for each switch individually.
  2. Editing the Configuration File: I was a bit nervous about editing config files, but it turned out to be straightforward. By accessing the integrations section and editing the Sonoff LAN configuration, I could specify the room for each switch.
  3. Testing the Changes: After making the changes, I restarted Home Assistant to ensure everything updated properly. It worked like a charm! Now, each switch appears in its designated room, making my setup much more organized.
  4. Tips for Others: If you’re new to this, don’t hesitate to dive into the configuration files. They’re well-documented, and small changes can make a big difference. Also, take advantage of the community resources and forums—they’ve been invaluable to me.
This experience taught me the importance of exploring different settings and not being afraid to tweak configurations. It’s rewarding to see everything working exactly as I envisioned!
I’d love to hear how others have organized their Sonoff switches or any tips they might have. Happy automating everyone! :rocket:
