Successfully Setting Up a Website Monitoring Automation
Hey everyone! I wanted to share my recent success in setting up an automation in Home Assistant that monitors an external website and triggers alerts when it goes down. This was a fun project that combined a bit of scripting with HA’s powerful automation capabilities. Let me walk you through how I did it and maybe you can learn something new or improve your own setups!
The goal was to create an alert system that would notify me if a specific website became unreachable. I wanted this to be non-intrusive but effective, so I decided on flashing lights and adjusting dimmers in key areas of my home. The automation should trigger after three consecutive failed attempts to reach the website, ensuring it’s not just a temporary glitch. Plus, I included a check against Google’s homepage to confirm if the issue is with the target website or my internet connection.
Here’s how I approached it:
  1. Script Development: I wrote a Python script that periodically checks the website’s availability. It uses wget to attempt a connection and logs the results. The script is designed to run every minute, striking a balance between responsiveness and resource usage.
  2. Automation Setup: In Home Assistant, I created a scene that handles the alerting process. This includes controlling lights and dimmers. The lights flash in a specific pattern, and the dimmers adjust to a lower setting to draw attention without being too disruptive.
  3. Integration with HA: I used HA’s MQTT discovery feature to integrate the script’s output into my dashboard. This way, I can monitor the status of the website in real-time and see when alerts are triggered.
  4. Testing and Refinement: I tested the setup extensively to ensure it works under different conditions. This included simulating website downtime, testing the alert patterns, and verifying the accuracy of the Google check.
One challenge I faced was ensuring the script’s reliability across different network conditions. I also had to fine-tune the alert duration and intensity to make sure it’s noticeable but not annoying. After some adjustments, everything worked smoothly!
I’d love to hear if anyone else has implemented similar monitoring systems or has tips for improving this setup. Maybe you have a different approach to website monitoring or a creative way to handle alerts. Let’s share our experiences and continue learning from each other!
Cheers to all the HA enthusiasts out there making their homes smarter and more automated! :tada:
