Successfully Setting Up Camera Notifications in Home Assistant
Hey everyone! I wanted to share my journey in setting up camera notifications in Home Assistant. It was a bit of a learning curve, but I managed to get it working smoothly. Here’s how I did it:
Problem: I wanted my doorbell camera to capture images and send them in notifications, but I kept getting a 404 error. I tried using the camera.snapshot service and passing the image to my phone, but it didn’t work as expected.
Solution: After some research, I realized the issue was with how I was referencing the image path. I adjusted the filename to ensure it was correctly formatted and accessible. Here’s the working configuration:
yaml
  • service: camera.snapshot
    data:
    filename: >-
    /media/snapshots/{{ trigger.to_state.last_changed | as_timestamp | timestamp_custom(“%Y-%m-%d_%H-%M-%S”) }}-frontdoor.jpg
    target:
    entity_id: camera.g4_doorbell_pro_high
    enabled: true
  • service: notify.mobile_app_iphone
    data:
    title: Frontdoor Notification
    message: Person detected at {{ now().strftime(‘%H:%M:%S’) }}
    data:
    image: >-
Tips:
  • Ensure the image path is correctly formatted and matches your Home Assistant setup.
  • Check your configuration.yaml for any typos or syntax errors.
  • If you’re still having trouble, try restarting Home Assistant or checking the logs for more detailed error messages.
It’s such a relief to have this working now! I can monitor my front door from anywhere, and the notifications are super helpful. If anyone has questions or needs further assistance, feel free to ask!
Happy automating! :rocket:
