Hey everyone! I just wanted to share my success in setting up a custom rule to control the volume of my Sonos speakers. I’ve been trying to figure this out for a while, and I’m thrilled to finally get it working smoothly. Let me walk you through how I did it and share some tips that might help others in the same situation.First, I identified the specific button I wanted to use for adjusting the volume. I found that using the on_click event was the most reliable way to trigger the volume change. I set up two separate rules—one for increasing the volume and another for decreasing it. This setup ensures that each button press has a clear action, making it easy to troubleshoot if something goes wrong.Here’s a quick breakdown of the steps I took:- Defined the Button Events: I mapped the on_click event to trigger the volume adjustment.- Set Up Volume Increments: I decided on a comfortable increment of 5% for each button press. This prevents sudden loud noises and makes the adjustment gradual.- Tested the Setup: I tested the rule multiple times to ensure it worked as expected and made adjustments where necessary.One thing I learned is the importance of testing in a quiet environment to accurately gauge the volume changes. It also helped to have a second person press the button while I monitored the system, ensuring everything was in sync.For those looking to implement a similar setup, here are a few tips:- Start Small: Begin with a modest volume increment and adjust based on your comfort level.- Use Consistent Naming: Keep your rule names and button labels clear and consistent to avoid confusion.- Document Your Process: Write down each step as you go. This will be invaluable if you need to troubleshoot later.I’m really happy with how this turned out and can’t wait to expand on it further. If anyone has additional suggestions or tips, I’d love to hear them! ![]()
