Successfully Setting Up Sunrise/Sunset Automation
Hey everyone, I wanted to share my experience setting up a sunrise/sunset automation for my LED light strips. At first, I was a bit overwhelmed because I couldn’t get it to work properly, but with some research and help from the community, I finally got it sorted out! :sun_with_face:I’ve always loved how my lights automatically adjust based on the time of day, but I wanted something more seamless. After reading through some tutorials and experimenting with different settings, I realized the key was to use the built-in sunset and sunrise sensors in my system. Here’s a quick tip: make sure your time zone is correctly set in your smart hub settings—it was the little detail I overlooked at first. One thing that tripped me up was understanding how to link the sensors to my lights. I ended up creating a simple rule where the lights dim to 30% at sunset and turn off completely at 10 PM. It’s such a small change, but it’s made a huge difference in my daily routine. No more manually adjusting the lights—everything happens automatically now! :dart:I also found a fantastic resource in the forums where someone shared their exact setup. They recommended using a template sensor to combine different light conditions, which I adapted for my own setup. If anyone is struggling with similar issues, I’d highly recommend checking out their guide—it’s super detailed and easy to follow.Overall, this experience taught me the power of community and how a little persistence can go a long way. I’m now more confident in tackling other automation projects around my home. If you’re looking to dip your toes into smart home automation, start small and don’t be afraid to ask for help—this community is amazing! :bulb:Happy automating, everyone! :rocket:
