Hey everyone, I wanted to share my recent experience with integrating some Z-Wave battery-powered devices into my OpenHAB setup. While it was a bit of a challenge at first, I managed to get everything working smoothly in the end!
Initially, I was having trouble getting my Philio PST02-1C and Fibaro FGK10x devices to initialize properly. The logs were showing that the devices were waking up but not completing the initialization process. I tried everything from manually waking them up multiple times to re-adding them, but nothing seemed to work consistently.
After some research and reaching out to the community, I found that the issue was related to the timing and frequency of wake-up commands. Here’s what I did to resolve it:
- I ensured that the Z-Wave controller was set to the correct mode for handling battery-powered devices.
- I adjusted the wake-up intervals in the OpenHAB configuration to give the devices enough time to respond fully.
- I used the debug logs to monitor the initialization process closely and identify any lingering issues.
Finally, after a bit of patience and tweaking, the devices started initializing correctly and are now fully functional within my smart home setup. It was a bit of a learning curve, but it’s so satisfying to have everything working as intended!
If anyone else is struggling with similar issues, I’d be happy to share more details or help troubleshoot. Happy smart home tinkering everyone! ![]()
