Successfully Using GE Link PAR38 Bulbs with Philips Hue Without Extra Hub
Hi all,
I came across a query about whether you need a GE Link or Wink hub to use their PAR38 bulbs with Philips Hue. I thought I’d share my experience since I’ve been using GE Link PAR38 bulbs with my Hue system without any additional hubs, and it’s been working great!
Setup and Configuration
I currently have a Philips Hue system with several A19 and BR30 bulbs, and recently added two GE Link PAR38 bulbs. Initially, I was a bit concerned about compatibility, but the process turned out to be straightforward.
  1. Adding the Bulbs:
    I simply powered on the GE Link PAR38 bulbs and held down the button on my Hue bridge for 10 seconds to put it into pairing mode. The app automatically detected the new bulbs and added them to my setup.
  2. App Integration:
    The Hue app recognizes the GE Link PAR38 bulbs as regular Hue bulbs, which is fantastic. They appear under the “Lights” section, and I can control them just like any other Hue bulb.
  3. Performance:
    The PAR38 bulbs are perfect for my recessed lighting fixtures. They offer smooth dimming, a wide color spectrum, and energy efficiency. Plus, the fact that they’re Zigbee-based means they integrate seamlessly with my existing smart home ecosystem.
Tips for Others
If you’re considering adding GE Link bulbs to your Hue setup, here are a few tips:
  • Ensure Zigbee Compatibility:
    Make sure your Hue bridge supports Zigbee. The Hue bridge does, so it should work with any Zigbee-compatible bulbs, including GE Link.
  • Firmware Updates:
    Keep your Hue bridge firmware up to date. Updates often include improvements for third-party device compatibility.
  • Experiment with Scenes:
    The Hue app allows you to create scenes combining different lights. I created a “Dinner Mode” scene that dims both my Hue and GE Link bulbs to create a warm, cozy atmosphere.
I’m really happy with how the GE Link PAR38 bulbs have enhanced my Hue system. They provide the functionality I need without the hassle of additional hubs or complicated setups. If you’re looking to expand your smart lighting options, I highly recommend giving GE Link bulbs a try!
Let me know if anyone has questions or needs further assistance!
Best,
