Suggestion: Zigbee connection path
Is it possible to show connection path for Zigbee devices or even third party Matter devices? It helps a lot in solving connectivity problems for end devices.
I keeps on getting my E1 Curtain bots randomly going offline and rebooting the M3 does not fix the problem. I will need to delete and re-add the device every time. I suspect that the E1 curtains bots are connected to M3 via a Z1 pro switch and that may have spotty signal strength. But it is hard to troubleshoot when so many devices CAN BE the issue without knowing how the devices connection paths are…
I am also looking for this
That may work if you only have hubs or one or two repeaters. Imaging you have all the switches in the area (more than 8) that are connected to the M3 and anyone of them can act as the repeater to the end device…
