Installing a T1 sensor to switch off inverter and radiator heating via Home Assistant as such ensuring not to keep heating the room. This works for both dumb inverter via smart plug and Evohome radiator hub system, simple cheap and effective!
@leo_kretzers1 Hi there! Thanks so much for sharing this clever setup with the community. It’s always inspiring to see how users leverage tools like the Aqara Door and Window Sensor T1 and Home Assistant to create efficient, energy-saving automations. Your approach of turning off heating when a window is open is a practical way to avoid wasting energy.
We really appreciate you taking the time to post your solution—it helps fellow smart home enthusiasts find simple and effective ideas. Keep up the great sharing!
Same idea here, and in winter it saves a lot. Two small things I would add:
- Put a delay on the trigger, like “open for 2 minutes”. If not, the heating stops each time someone opens the window for 10 seconds.
- When the window closes, go back to the previous setpoint, not a fixed one. In HA you can create a scene on the fly (scene.create) just before turning off, and turn it back on after.
