Hi everyone, I wanted to share my experience with integrating the Tado smart thermostat into my existing home automation setup. I’ve been using Tado for a while now, and it’s been a great addition to my system. However, I recently ran into an interesting challenge that I thought I’d document here in case others are facing similar issues.
I have a Vaillant boiler connected to a manifold, which controls both the underfloor heating in my kitchen and the radiators throughout the rest of my house. I installed a wired Tado thermostat in the kitchen and a wireless one in the living room, both connected to a receiver that communicates with the boiler. The setup seemed straightforward, but I noticed an unexpected behavior: when the underfloor heating in the kitchen was on, the radiators in the rest of the house would also activate. This wasn’t the intended functionality, and it led to some inefficiencies in my heating system.
I reached out to the Tado support team, and they suggested using smart TRVs (Thermostatic Radiator Valves) to control the radiators independently. While this is a viable solution, I was curious if there was a way to achieve this without adding more devices to my setup. I started digging into the Tado app and the boiler’s configuration to see if there was a way to send heat selectively to different zones.
After some research, I discovered that the boiler itself might not support selective heating zones as seamlessly as I hoped. This led me to explore alternative configurations, including tweaking the Tado settings and adjusting how the boiler communicates with the thermostats. I also consulted with my boiler installer to ensure that the hardware setup was optimized for this kind of zoning.
The journey has been a bit of a learning curve, but it’s been fascinating to see how different components of a smart home system can work together—or sometimes against each other! I’d love to hear if anyone else has tackled a similar challenge or has insights into optimizing Tado and Z-Wave controller integration for better zone-specific heating control.
In the meantime, I’ll keep experimenting and sharing my findings here. Happy tinkering!
