Tasker app not receiving aqara events
I use the Tasker app to write apps for my Android cell phone. I have apps that respond to device events. For example I currently have Wyze door contact sensors. When a door opens, closes my Tasker app receives the event and processes it.
Itv doesn’t seem to work consistently with the Aqara app and contact sensors. Sometimes ac door opens closes, I get the event. Sometimes it can take several seconds to get the event, sometimes not at all. It seems like I have keep the Aqara app open, but it still does not send events consistently. When I check the Aqara app itv indicates that the was indeed opened closed, but no event sent.
Am I missing something in the setup? The Wyze app works consistently with its devices.
Thanks.
@larry_schweyer It sounds like you’re experiencing some issues with the Aqara app and your contact sensors not consistently communicating with the Tasker app. Based on the information in the reference, there are a few things you might want to check or try:
  1. Distance and Signal Interference: Ensure that your Aqara sensor is not too far from the hub or mounted on a metal surface, which could interfere with the signal. Moving the device closer to the hub might help improve communication consistency.
  2. Battery Levels: Low or dead batteries can affect the sensor’s performance. Make sure the batteries are fresh to ensure consistent event detection.
  3. Network Issues: For Zigbee devices, ensure the signal value is above 60. If it’s a WiFi device, the RSSI should be above -70 dBm. Adjusting the distance from the router may enhance performance.
  4. App and Device Communication: Sometimes, restarting the device or re-entering the network can help reestablish the communication connection. This might be worth trying if the problem persists.
Unfortunately, if these steps don’t resolve the issue, it might require further investigation. Please consider reaching out to Aqara’s customer service for more detailed assistance. You can contact them via the Aqara Home App (Profile > Help & Feedback > Customer Service) or by scanning the QR code:
If you don’t have an Aqara Home account, you can create a ticket here.
I hope these suggestions help! Feel free to share any updates or additional questions you might have.
Thanks for the tips. Tried pretty much all of those. A strange thing is, I’ll open a door and, it happens a lot, my app will get the event several minute later. Also after the door opens, I might pick up my cell and then I start getting events.
And… When I check the Aqara app after I get the delayed event, the app shows that the event occurred when it did, but my app gets the event minutes later.
I find that of I reboot my cell, it seems to help.
