Hi everyone, I wanted to share my experience with setting up a temperature control automation for my baby’s room. It’s been a game-changer for ensuring a comfortable environment for my little one. Here’s how I did it:
First, I identified the specific time window when I needed the temperature to be adjusted. After some research, I found that maintaining a temperature between 68°F and 72°F (20°C to 22.2°C) is ideal for a baby’s room. I decided to set this temperature adjustment to happen during the night when the baby is sleeping, specifically between 8 PM and 6 AM.
I used Home Assistant’s automation feature to create a rule that triggers at these specific times. The automation adjusts the thermostat to the desired temperature and also ensures that certain eco-friendly features are temporarily disabled during this period. This way, energy efficiency doesn’t compromise the baby’s comfort.
Here’s the setup I used:
yaml
alias: Baby Room Temperature Control
trigger:
platform: time
at: ‘20:00:00’
condition:
condition: state
entity_id: binary_sensor.baby_room_occupied
state: ‘on’
action:
service: climate.set_temperature
data:
entity_id: climate.baby_room_thermostat
temperature: 68
Similar automation for 6 AM
This automation has worked perfectly for me. The baby sleeps better, and I don’t have to worry about adjusting the temperature manually. It’s a small tweak that makes a big difference!
I hope this helps someone else looking to create a similar setup. Let me know if you have any questions or suggestions for improvement!
