I recently set up an ESP32 with a MAX6675 sensor and a TM1637 display to show temperature readings. Here’s how I did it, and some tips to avoid common pitfalls:
Step 1: Understanding the Components
- ESP32: The microcontroller that handles everything.
- MAX6675: A sensor that reads temperature from a thermocouple.
- TM1637: A 4-digit LED display module.
Step 2: Correct Configuration
Here’s the corrected configuration that avoids the reference issue:
yaml
esphome:
friendly_name: Termometro caldaia
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
logger:
api:
encryption:
key: “cancelled”
ota:
- platform: esphome
password: “cancelled”
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
ap:
ssid: “cancelled”
captive_portal: true
spi:
miso_pin: GPIO13
clk_pin: GPIO12
sensor:
- platform: max6675
cs_pin: GPIO45
update_interval: 10s
display:
- platform: tm1637
clk_pin: GPIO4
dio_pin: GPIO5
inverted: true
intensity: 3
lambda: |
it.print(0, id(temperature_sensor).state);
Key Fixes:
- Lambda Function: Instead of referencing a Home Assistant entity, we directly use the sensor’s ID (
temperature_sensor). - Sensor Naming: Simplified the sensor name for clarity.
- ESPHome Integration: Ensures everything is handled within ESPHome without external entity references.
Step 3: Testing
After uploading the configuration:
- Check the ESPHome dashboard to ensure the sensor is reading correctly.
- Verify the display shows the temperature in real-time.
Troubleshooting Tips:
- Check Connections: Ensure all wires are correctly connected, especially the SPI pins.
- Power Supply: Make sure the display has a stable power supply; TM1637 can be sensitive.
- Sensor Placement: Ensure the thermocouple is properly connected and placed in the environment you’re measuring.
This setup is a great way to monitor temperatures in real-time without needing external servers or complex integrations. It’s also a good learning project for understanding how sensors and displays work together in ESPHome!
If you have any questions or run into issues, feel free to ask!
