Temperature-triggered Automation: A Smooth Solution
I recently embarked on a project to automate my home’s ventilation system based on temperature differences between indoors and outdoors. The goal was straightforward: turn on the ventilation when the outside temperature is lower than inside. Sounds simple, right? Well, it turned out to be a bit of a puzzle, but I managed to crack it with some research and experimentation.
Initially, I set up a basic automation using Home Assistant’s template triggers. I used two temperature sensors—one inside and one outside—and a switch to control the ventilation. The idea was to compare the two temperatures and trigger the switch accordingly. However, despite tweaking the configuration multiple times, the automation didn’t activate as expected. It was frustrating, especially when I manually tested the logic and it worked perfectly.
After some digging, I realized the issue was with how the automation was processing the temperature values. The template trigger wasn’t correctly evaluating the conditions in real-time. To fix this, I switched to using a different automation structure, leveraging Home Assistant’s powerful state triggers and conditions. This approach allowed me to define clear rules based on the temperature difference and ensured the automation responded accurately.
Here’s a snippet of the working configuration:
yaml
alias: Temperature-based Ventilation
trigger:
  • platform: state
    entity_id: sensor.outside_temperature
    condition:
  • condition: template
    value_template: ‘{{ states.sensor.inside_temperature.state | float > states.sensor.outside_temperature.state | float }}’
    action:
  • service: switch.turn_on
    entity_id: switch.ventilation
    This setup checks the outside temperature whenever it changes and compares it to the inside temperature. If the inside is warmer, the ventilation turns on, ensuring fresh air flows in efficiently.
This experience taught me the importance of understanding how different automation platforms process data and the value of community resources. By sharing my journey, I hope it helps others facing similar challenges. Happy automating! :rocket:
