Template Sensor Issues and Workarounds
Hi everyone, I wanted to share my experience with template sensors in Home Assistant. While they are incredibly powerful, I’ve encountered a few quirks that might be helpful for others to know about.
Recently, I noticed that using {{ none }} in a template sensor with a unit of measurement was causing issues. The sensor would throw an error because {{ none }} was being interpreted as the string 'None' instead of Python’s NoneType. This was particularly problematic for optional numeric sensors, like those used for financial calculations or energy monitoring, where returning 0 isn’t always the right solution.
After some research, I found that wrapping the template in a conditional statement could help bypass the issue. For example:
yaml
{% if valid %}
{{ value }}
{% endif %}
This approach avoids the error but does suppress the explicit fallback, leaving the sensor in an unknown state unintentionally. It’s not perfect, but it’s a workaround until the underlying issue is resolved.
I’ve also been exploring the idea of stricter internal typing in Home Assistant to prevent such type mismatches. It would be fantastic if there were an option to enforce strict numeric output, ensuring that only numbers or None are returned. This would make template sensors even more reliable for complex use cases.
If anyone has encountered similar issues or has additional tips, I’d love to hear about your experiences! Let’s keep the discussion going and help each other troubleshoot these minor hiccups in our smart home setups. :rocket:
