The Ultimate Guide to Transitioning Aqara G4 Camera to Home Assistant Like A Pro
Hey everyone, just wanted to share a little success story in case it helps someone out there pulling their hair like I was last weekend.
So, I decided to move my Aqara G4 camera off the Aqara app and into Home Assistant directly. Sounds easy, right? Spoiler: it wasn’t… but now that it’s done, it actually wasn’t that bad, either — just took some digging and trial-and-error.
Context: I’m a smart home enthusiast, not a dev or anything fancy. I’ve got a mixed setup (mostly HomeKit, a bit of Zigbee stuff with ZHA) and recently started centralizing everything on Home Assistant. I wanted local control, better automation flexibility, and honestly, I just got tired of the delays and app hopping.
Now, for the G4 — I used the RTSP stream for video, and trick was enabling the HomeKit Secure Video feed while also grabbing the stream token for HA. The docs were kind of vague, but if you set up the camera in the Aqara app FIRST, enable RTSP, grab the URL, toss it in an HA generic camera integration — boom: solid feed in the dashboard.
For motion detection and doorbell support, I couldn’t get native events so I used some automation workarounds with MQTT and Node-RED to bridge from HomeKit events (since I kept the G4 added to HomeKit) into HA. It works well enough for now until better integration lands.
If you’re thinking of making the switch — test the stream link first, and definitely take time to label everything. I learned the hard way with 3 “front door” entities showing up in different dashboards.
Let me know if you ran into similar snags or found better workarounds — always down to tweak and improve!
@ThermoTamer Thank you so much for sharing your experience with transitioning your Aqara G4 camera to Home Assistant! It’s always inspiring to hear about successful integrations, especially when they come with practical tips and tricks. Your journey from app hopping to achieving local control with better automation flexibility sounds like a rewarding process, even with the initial hurdles.
Using the RTSP stream for the video and setting up the HomeKit Secure Video feed is a smart approach. It’s great that you could find a way to bring everything together using MQTT and Node-RED for motion detection and doorbell support. These workarounds can be quite handy until more seamless integration options are available.
Labeling entities properly is indeed crucial to avoid confusion across different dashboards—a lesson learned the hard way, but valuable nonetheless. Your insights will surely help others in the community who are looking to streamline their smart home setups.
Please keep sharing your updates and any new strategies you discover! Your experience could be incredibly helpful to others embarking on a similar path. :blush:
