I have a Floor Heating Thermostat W500 connected to my water-based underfloor heating system. Once the temperature on the thermostat reaches the desired level to switch on the heating, the relay clicks as expected but it takes exactly 2 minutes and 5 seconds to draw heat from wiring centre which then instantly switches the boiler on.
As soon as the sensor reaches the desired temperature to switch off it stops drawing heat immediately as expected.
I have tried the unit in multiple rooms and the delay is the same. Different brands of thermostat call for heat as soon as the relay was switched on so this feels like a software issue. Has anybody found the same problem with the unit?
@mr_mr It sounds like you’re experiencing a delay with your Aqara Floor Heating Thermostat W500 in activating your water-based underfloor heating system. From the information available, the thermostat is designed with advanced features for precise temperature control and energy efficiency, but there isn’t a specific mention of a delay in heating activation similar to what you described.
This could potentially be linked to the thermostat’s internal processing or the setup of your heating system. It’s also worth considering the thermostat’s energy-saving features, which may include mechanisms to manage heating efficiency and avoid unnecessary power usage.
While the reference information does not specifically address your issue, it may be helpful to explore the settings and automation options within the Aqara Home app to ensure optimal performance. You might also consider reaching out to the community for shared experiences and solutions.
If this seems like a persistent issue or if you suspect a software-related problem, it might be beneficial to contact Aqara’s Customer Service Team for further assistance. You can do this via the Aqara Home App (Profile > Help & Feedback > Customer Service) or by scanning the QR code provided:
@mr_mr I’m sorry to hear about the delay issue you’re experiencing with your Aqara Floor Heating Thermostat W500 connected to your water-based underfloor heating system. The reference information available doesn’t specifically address this 2-minute-and-5-second delay between the relay clicking and the boiler activating. It’s helpful that you’ve tested multiple rooms and noted the consistency, which gives a clear picture of the situation. Perhaps other community members have encountered similar issues and can share their insights. If you have suggestions for improvement, feel free to submit feedback through the Aqara Home App (Profile>Help&Feedback>Customer Service) for further assistance.
