TRÅDFRI Socket Update Issues
I recently encountered an issue with my TRÅDFRI socket, and I wanted to share my experience in case others are facing the same problem. After installing the socket, it immediately started showing a continuous update process. Despite multiple restarts and reconnections through Zigbee2MQTT, the issue persisted. I tried everything from power cycling the device to resetting it, but nothing seemed to work. I even reached out to the community for help, and while some suggested checking the firmware version, others recommended contacting support. I’m still hoping for a resolution, but I wanted to document my journey in case it helps someone else. If anyone has any additional insights or solutions, I’d greatly appreciate it!
