Transforming My Living Room with Govee Wall Sconces
I’ve recently completed a home project that I’m really excited to share! After months of planning, I finally installed a set of Govee H6087 Wall Sconces in my living room. The process was a bit challenging, but the end result is absolutely stunning.
I decided to go with a unique X pattern installation, which adds a modern touch to the space. Instead of the traditional up or down orientation, I wanted something that would make the wall feel more integrated and less left out. Running the wires inside the wall was a bit of a DIY adventure, but it made the setup look seamless.
One of the highlights was creating a custom DIY Cylon eye effect for these sconces. None of the existing models worked perfectly, so I took the plunge and designed my own. The result is something truly unique that adds a fun tech vibe to my living room.
If you’re considering a similar project, I’d recommend starting with a clear plan and maybe even sketching out the layout beforehand. Testing different patterns and ensuring the wiring is done safely is crucial. The effort really pays off in the end!
I’m now looking into how I can integrate these sconces with my existing smart home setup for even more automation fun. Stay tuned for more updates as I continue to explore the possibilities!
