Hey everyone!
I’m trying to set up my smart lights using Homey, but I’m running into an issue with dimming. I’ve got a KlikAanKlikUit ACM-250-LD dimmer controlling some LED lights, and while I can adjust the brightness through the Homey app, it doesn’t quite hit the levels I want. ![]()
When I use the slider, the lights either end up too bright or too dim, which is frustrating. I’ve tried using a flow with a percentage-based adjustment, but the same issue persists—21% is too bright, and 20% is too dim. ![]()
Interestingly, when I use the physical dimmer or an old-school switch, it works perfectly. I’ve also experimented with the dimmer settings for phase cutting and such, but nothing’s helped. ![]()
Does anyone have any tips or tricks for getting the dimming just right through Homey? I’d love to get this sorted out so I can fully enjoy my smart lighting setup! ![]()
