Troubleshooting Aqara Door & Window Sensors with M3 Hub
I’ve recently set up my Aqara Hub M3 with four Door & Window Sensors P2 units, and while they do work, the reliability leaves a lot to be desired. Let me walk you through my experience and the troubleshooting steps I’ve taken so far.
First off, I tested each sensor individually during setup, placing them right next to the hub. They responded correctly, but after some time, the sensors started behaving unpredictably. For instance, removing the magnet from a sensor didn’t always trigger an alert, and sometimes the sensor would remain in the open state even after closing. This inconsistency is frustrating, especially since connectivity isn’t an issue—the hub has a strong Wi-Fi signal.
I also encountered problems during the pairing process. While adding sensors using the latest iOS version didn’t work smoothly, switching to an Android phone resolved the issue. However, the sensors still aren’t reliable.
Here’s what I’ve tried so far:
  • Rebooting the hub and sensors.
  • Testing sensors one by one.
  • Ensuring the hub’s firmware is up to date.
  • Checking for any environmental interference.
Despite these efforts, the problem persists. I’m hoping this is a temporary glitch that will be fixed in future updates. In the meantime, I’m curious if others have faced similar issues and how they’ve managed to resolve them. Any insights or tips would be greatly appreciated!
Until then, I’ll keep experimenting and monitoring the sensors’ behavior. Hopefully, we can find a workaround or a solution to make this system as dependable as it should be.
I have had spotty reliability with the P2 sense installation. But this was solely a HomeKit connection. I am moving it over to the M3 to see if that works any better.
