Hey everyone, I wanted to share my recent experience with setting up an ESP32-Camera for my home security setup. It was a bit of a rollercoaster, but I managed to get it working smoothly in the end!
Initially, I faced some frustrating issues where the camera would freeze after just 5 seconds of operation and only display a grayscale image. I tried tweaking the configuration, checking the power supply, and even re-flashing the firmware, but nothing seemed to work consistently.
After some research and trial and error, I discovered that adjusting the camera settings in the ESPHome YAML file made a huge difference. Lowering the resolution to CIF and reducing the framerate to 15fps helped stabilize the video feed. I also optimized the GPIO pin configuration to ensure proper signal integrity.
Here’s a snippet of the working configuration I ended up with:
yaml
esp32_camera:
name: ESP32-CAM Security Camera
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
max_framerate: 15fps
idle_framerate: 0.05fps
resolution: CIF
jpeg_quality: 20
I also made sure to use a stable 12V power supply for the ESP32-Cam to avoid voltage drops that might cause freezes. Additionally, I implemented a watchdog timer in the code to automatically reset the camera if it freezes.
After these adjustments, the camera has been running smoothly for over a week now! It’s been a great learning experience, and I’m so glad I didn’t give up. If anyone else is struggling with similar issues, I’d recommend experimenting with different camera settings and ensuring a clean power supply. Happy coding everyone! ![]()
