Troubleshooting Home Assistant URL Issues After Update
Hey there! I hope you’re having a great day. I wanted to share some insights and troubleshooting steps regarding the issue you’re facing with your Home Assistant setup after updating to version 6.0. Let’s dive into it!
Understanding the Issue
You mentioned that after updating to Home Assistant 6.0, the URL http://homeassistant.local:8123 is no longer working. This could be due to changes in the update that might have affected how the service is running or how it’s being accessed.
Possible Causes
  1. DNS Resolution Issues: The error message DNS_PROBE_FINISHED_NXDOMAIN suggests that the domain name homeassistant.local isn’t resolving properly. This could be because the service responsible for advertising the .local domain (like Avahi or mDNS) isn’t running correctly after the update.
  2. Port Configuration: It’s possible that the update changed the default port or how the service is configured to listen on that port.
  3. Service Availability: The Home Assistant service might not be running correctly, or it might have been disabled during the update process.
Troubleshooting Steps
Let’s go through some steps you can take to resolve this issue:
1. Check the Service Status
First, ensure that the Home Assistant service is running. You can do this by accessing your system’s command line (SSH) and running:
bash
sudo systemctl status home-assistant@homeassistant.service
If the service isn’t running, you can start it with:
bash
sudo systemctl start home-assistant@homeassistant.service
2. Verify Network Connectivity
Try accessing the web interface using the IP address instead of the domain name. For example, if your Home Assistant is running on 192.168.86.40, you can try:
bash
http://192.168.86.40:8123
If this works, the issue is likely with the domain name resolution, not the service itself.
3. Check Avahi/mDNS Service
If the .local domain isn’t resolving, it might be because the Avahi service isn’t running. You can check the status of Avahi with:
bash
sudo systemctl status avahi-daemon
If it’s not running, you can start it with:
bash
sudo systemctl start avahi-daemon
And enable it to start on boot with:
bash
sudo systemctl enable avahi-daemon
4. Adjust Configuration Files
Sometimes, updates can change the default configuration. Check your configuration.yaml file to ensure there are no errors. You might also want to specify the base_url in your configuration:
yaml
http:
base_url: http://homeassistant.local:8123
5. Restart the System
If none of the above steps work, a hard reboot of your system might resolve the issue. Sometimes, services don’t start correctly after an update, and a reboot can help.
6. Review Logs
Check the logs for any errors or warnings that might give more insight into the issue. You can access the logs through the Home Assistant web interface under Configuration > Logs or by running:
bash
journalctl -u home-assistant@homeassistant.service -b
Conclusion
By following these steps, you should be able to identify and resolve the issue with accessing your Home Assistant instance. If you’re still having trouble, feel free to share more details, and I’d be happy to help further!
Happy tinkering! :blush:
