Have you ever struggled with getting iOS notifications to work in Home Assistant? I know I have! After spending hours tweaking my configuration and trying every possible fix, I finally managed to get things working smoothly. Let me share my journey and some tips that might help others facing similar issues.
First, I want to acknowledge how frustrating it can be when notifications just don’t show up. I tried everything from manually sending test notifications to reinstalling certificates, but nothing worked. The logs kept showing connection errors, and I was stuck wondering if it was a Docker issue or something else entirely.
One thing I discovered was the importance of DNS resolution within Docker containers. If your container can’t resolve DNS properly, it will fail to connect to the notification server. I fixed this by adjusting my Docker setup, but I still faced connection issues. It turned out that the certificates I had installed weren’t being recognized correctly. I had to manually add them to the iOS settings on my phone, which was a bit of a pain but ultimately solved the problem.
Another tip I’d share is to test your notifications in small steps. Start by sending a simple notification without any custom categories or actions. Once that works, gradually add complexity. This approach helped me isolate the issue and pinpoint exactly where things were going wrong.
If you’re still struggling, don’t hesitate to reach out to the community. There are so many helpful people here willing to lend a hand. Remember, persistence pays off, and even the most frustrating tech issues can be solved with the right approach!
Happy automating, and I hope this helps someone out there avoid the endless loop of troubleshooting! ![]()
