I’ve been working on setting up an automation system for my hallway lighting, and I wanted to share my experience and some tips in case anyone else is facing similar challenges.
The Goal: I wanted my hallway lights to turn on automatically when motion is detected between 6 PM and 6 AM, stay on as long as motion is detected, and then turn off 45 seconds after the last motion. Sounds simple enough, right?
The Problem: Initially, everything worked as expected. The lights would turn on when I walked into the hallway, and they stayed on as long as I was moving around. However, after a few days, I noticed that the lights were turning off after 45 seconds, even if I continued to move in the hallway. This was frustrating because it defeated the purpose of the automation—I wanted the lights to stay on as long as I was present.
What I Tried: I checked the automation code to see if there were any issues. I added a condition to check if the motion sensor was still detecting motion, and I adjusted the delay time to different values. I also reviewed the motion sensor settings to ensure it wasn’t malfunctioning. Despite these efforts, the problem persisted.
The Solution: After some research and experimentation, I realized that the issue was with the way the automation was structured. The delay was set to trigger after the initial motion detection, but it didn’t account for continuous motion. To fix this, I adjusted the automation to reset the delay every time motion was detected. This way, the lights would stay on as long as there was motion, and only turn off after 45 seconds of inactivity.
Tips for Others:
- Test Thoroughly: Always test your automations under different conditions to ensure they work as expected.
- Review Conditions: Double-check your conditions and delays to make sure they align with your desired outcome.
- Experiment: Don’t be afraid to tweak your settings and test different configurations until you find what works best for your setup.
Final Thoughts: While setting up this automation was a bit of a challenge, it taught me a lot about how to structure and troubleshoot automations in Home Assistant. I’m now confident in my ability to create more complex and reliable automations for my smart home. If anyone has questions or needs help with similar setups, feel free to reach out—I’m happy to share what I’ve learned!
