Troubleshooting Nest Thermostat Fan Mode Display
Hey everyone, I wanted to share my experience with the Nest Thermostat fan mode display issue. After some research and trial and error, I found a workaround that might help others facing the same problem.
The Issue:
I noticed that my Nest Thermostat wasn’t displaying the fan mode correctly when it was running on a schedule. It worked fine when I manually turned the fan on, but not through the automatic schedule set in the Google Home app. This was a bit frustrating as I rely on the schedule to ensure proper air circulation.
The Workaround:
After some digging, I discovered that adjusting the fan mode settings directly in the Google Home app and ensuring that the schedule was set up correctly resolved the issue. Here’s what I did:
  1. Check the Schedule:
    • Open the Google Home app.
    • Navigate to your Nest Thermostat.
    • Go to the ‘Fan’ section and ensure the schedule is correctly set up.
  2. Adjust Fan Settings:
    • Make sure the fan mode is set to ‘Auto’ or ‘On’ depending on your preference.
    • Save any changes you make.
  3. Test the Schedule:
    • Wait for the scheduled time to see if the fan turns on as expected.
    • Manually check the fan status in the app to confirm it’s running.
Additional Tips:
  • If the issue persists, try resetting the Nest Thermostat to its factory settings and reconfiguring it.
  • Ensure your Google Home app is updated to the latest version.
  • Check if there are any firmware updates available for your Nest Thermostat.
I hope this helps someone else who’s experiencing the same issue. It’s a minor inconvenience, but with a bit of tweaking, it can be resolved. Let me know if you have any questions or if there’s another workaround that’s worked for you!
Best regards,
