Hey everyone! I recently encountered an issue with my Shelly Flood device not appearing in the cloud, and I wanted to share my experience and solution in case others are facing the same problem.
After setting up the Shelly Flood in my home network and enabling the cloud feature, I noticed that it wasn’t showing up in the cloud interface. I double-checked the network settings, ensured the device was properly connected, and even reinstalled the app, but the issue persisted.
Frustrated but determined, I decided to dig deeper. I reset the Shelly Flood to factory settings and went through the setup process again, making sure to follow each step carefully. To my relief, the device finally appeared in the cloud.
It turns out that a simple factory reset and reconfiguration were all that was needed. Sometimes, a fresh start can resolve unexpected issues. I also ensured that the firmware was up to date, which is always a good practice to maintain optimal performance.
For anyone else experiencing similar issues, here are a few tips:
- Check your network settings and ensure the device has a stable internet connection.
- Reset the device to factory settings and go through the setup process again.
- Verify that the firmware is up to date.
- If the problem persists, contact Shelly support for further assistance.
I hope this helps someone else who’s struggling with similar connectivity issues. It’s always a bit stressful when devices don’t work as expected, but with patience and persistence, most problems can be resolved. Happy tinkering! ![]()
