Hello everyone, I hope this message finds you well. I’m currently facing some challenges while trying to set up my new Wyze Cam here in the Dominican Republic. Despite having a stable internet connection, I’m struggling to connect the camera to my network. I’ve tried both my home Wi-Fi and a mobile hotspot from my phone, but every attempt results in a connection timeout.
I’m curious if the issue might be related to the Wi-Fi band—specifically, whether I need to use a 2.4 GHz connection instead of 5 GHz. Does anyone have any insights or tips on how to determine if my setup is using the correct band?
I’ve followed the setup instructions carefully, but nothing seems to work. It’s quite frustrating, especially since I was really looking forward to using this camera for home monitoring. If anyone has successfully set up a Wyze Cam in a similar situation or has encountered this issue before, I’d greatly appreciate any advice or troubleshooting steps you could share.
Thank you in advance for your help! Cheers, [Your Name]
