Two-way set-up with two H2 switches and 2Aqara lightbulbs
Hello, currently have 2 regular switches with two lightbulbs in a two-way set-up. When I click one switch It turns them on when I click again or the other switch it turns them off. I’ve replaced both switches with Aqara H2 switches and both lightbulbs have also been changed to Aqara lightbulbs. What is the correct wiring that should get me to continue to use both switches and lights in a two-way set-up?
Best regards,
André
Hi! I’ve explained the options of connecting a H2 switch in such setup in this post.
If both switches are connected with neutral, then you can enable decoupled mode and control the light with an automation.
The automation should look like this
WHEN (any action triggers the automation
Switch 1 button click
Switch 2 button click
THEN
turn switch 1 on/off
turn switch 2 on/off
Thanks to this setup, when you click any switch, then both switches will be able control the light
