U100 Showing Twice in HomeKit – No Option to Remove
I just noticed that my Aqara U100 smart lock is appearing twice in the Apple Home app. One instance works fine, but the duplicate shows as “Not Responding.” When I tap it, there’s no option to remove or unpair it from HomeKit.
Things I’ve tried so far:
• Restarted my iPhone and Home app
• Restarted the Aqara Hub
• Checked firmware updates for both the hub and the lock
No luck so far. Has anyone else run into this issue? If so, how did you remove the duplicate entry without having to completely reset the lock?
I use Android, but my kids use iPhone and i am interested in your post because i want be able to set up their phone to work with Apples Home app.
I see this is almost 12months old and no reply. Did you get this sorted?
To remove the second instance, open home app, then settings for the home, and look under home hubs and bridges. If you see the aqara hub listed as a bridge, remove it. The secondary instance will be removed with it.
