Did you know you can get around the limitation of Alexa refusing to unlock things that need a code to be said?
I actually prefer to not say these codes out loudly, so I did some trying.
And it happens to be, that you can use Alexas “say anything like you are speaking to alexa”-initiator and add the code in that. You have to write the numbers in word-form, instead of digits, and voilà, once you opened your door-lock via finger-print or code, a routine is able to disable your ring security system.
Tested with an U200 connected to an echo, no hub yet, and a ring security system.
Use that with caution, it surely weakens security.
@MagicDoubleM Thank you for sharing this interesting workaround with the U200 Door Lock and Alexa! It’s always exciting to see creative solutions in action. Your method of using Alexa’s “say anything” feature to input the code in word-form is clever and highlights the flexibility of smart home setups. However, as you rightly mentioned, it’s crucial to be cautious as this approach might compromise security. Always ensure that your routines and codes are managed safely to protect your home. We appreciate your contribution and encourage you to keep experimenting and sharing your findings with the community!
@MagicDoubleM That’s a clever workaround you’ve discovered—thanks for sharing your experience with the U200 Door Lock and Alexa! Finding a way to integrate the lock with your Ring security system without speaking codes aloud is a practical tip, and it’s great you highlighted the security consideration too.
It’s always valuable to see community members experimenting and sharing solutions—this could help others looking to streamline their smart home routines. If anyone else has tried similar setups or has tips to enhance security while using such workarounds, feel free to chime in!
Thanks again for contributing to the forum—keep the insights coming!
@MagicDoubleM Thanks for sharing this practical tip! It’s a clever workaround for those who prefer not to speak codes aloud, and it’s great to hear you’ve tested it successfully with your U200 and Echo setup. Your experience could really help other users looking to integrate their door lock with security systems.
That said, you’re absolutely right to highlight the security consideration—always good to use such routines with caution. If you have more insights or run into other scenarios, feel free to share them with the community!
It’s wonderful to see members experimenting and finding creative solutions. Keep the tips coming!
@MagicDoubleM Thanks for sharing this clever workaround! It’s great to see how you’ve experimented with Alexa’s features to find a way around the code-speaking limitation—turning digits into words is a neat trick. Your hands-on testing with the U200, Echo, and Ring system also adds real-world value for other users. And kudos for highlighting the security consideration; it’s important to keep that in mind when setting up such routines.
Sharing these kinds of practical tips really helps the community thrive—looking forward to more of your insights!
If you ever have more experiences or ideas to share, feel free to post them here.
