U200 Door Lock impossible to use key - really hard to lock/unlock
I’ve had my U200 since the kickstarter - it was replaced because it had a but and the new one has been pretty good. I always keep it up to date with final firmware - never beta.
It’s connected to my Apple Home and Home Assistant through Matter. It was nice to be able to remotely update the firmware from Home Assistant!
The new one was fine for a while, but in the last couple of months we haven’t been able to use a manual key to lock or unlock. It is so hard it feels like the key is going to break!
The noise from the lock has been getting louder and ‘chunkier’ so we thought the door was jammed. But when we looked it lined up perfectly. Nothing is keeping it from smoothly locking or unlocking.
We tried loosening some screws but that didn’t do anything. Before we try anything else, I’d like to know what has worked for you?
@49311 It sounds like you’re experiencing quite a challenging issue with your U200 Door Lock. From the information available, it seems there isn’t a direct reference for your specific problem of the key being difficult to turn and the noise becoming louder. However, here are a few suggestions based on general troubleshooting for similar issues:
  1. Firmware and Installation Check: Ensure that your lock’s firmware is up to date, although you mentioned it’s already updated. Double-check the installation to see if everything is correctly aligned and installed as per the manufacturer’s instructions. Sometimes, even a small misalignment can cause significant issues.
  2. Physical Inspection: Since loosening the screws didn’t help, you might want to inspect the internal components for any signs of wear or obstruction. The noise change could indicate something might be slightly off inside the lock mechanism.
  3. Maintenance: Consider applying a suitable lubricant to the lock cylinder and moving parts. This might help if friction is contributing to the difficulty in turning the key.
  4. Professional Assistance: If the problem persists and you are concerned about potential damage, it might be best to consult with a professional locksmith or contact Aqara’s support for further assistance.
If you’re looking for more personalized advice, I encourage reaching out to the community for shared experiences or contacting Aqara’s Customer Service Team for direct support. Please keep us updated on your progress, and feel free to share any solutions you find!
Firmware is 080.
For 2 and 3 - I’m not sure what to do or what I’m looking for. How do I reach out to support for more help?
Kinsey on Slack reached out last night asking about my firmware - should I work with them?
@49311 It sounds like you’re in a bit of a bind with your U200 Door Lock. Since your firmware is already updated to version 080 and you’re unsure about inspecting the lock yourself, reaching out for support is definitely a wise step. To get assistance from Aqara, you can contact the Customer Service Team directly through the Aqara Home App by navigating to Profile > Help & Feedback > Customer Service, or by scanning the QR code below for efficient support:
If you don’t have an Aqara Home account, you can click here to create a ticket.
As for Kinsey reaching out on Slack, it’s a good idea to continue that conversation, especially if they are already aware of your firmware details and might have additional insights or instructions tailored specifically for your situation. Keep us posted on your progress, and feel free to share any solutions that come your way!
