U200 notifications and auto-lock
Not had my U200 long, and for the most part I love it. But a couple things bugging me which I hope someone here can help with.
The auto-relock when you close the door. I have it set to 3 seconds, and half the time it works perfectly. But if the door is left open a little while it tries to turn the latch while fully open, then when you close the door doesn’t lock. You have to unlock it and then re-lock it manually. I have tried re-calibration several times, and tested different settings, but nothing seems to work. Has anyone else had a problem with this?
The other niggle I have is in the app. I have tried to disable the notifications of the door being locked and unlocked, as I live alone so know when I open my door. But despite disabling all device notifications they are still showing up in the app. How do you disable them for just the locking and unlocking events?
I only want notifications if the door is left unlocked for a time, or the battery is running low.
Hello, welcome to the forum. Notifications can be turned off here. The best option for monitoring the status of doors is a regular opening sensor placed on the door and creating automation. That’s how I use it.
First thing I had done. Then tried turning off ALL device notifications. Still getting them :exploding_head:
No, for some reason I want to turn it off exactly as I wrote.
And I have separate contact sensors on the doors already too… for that same reason
The U200 also sometimes doesn’t seem to update its locked status every time, triggering my door left unlocked automation… seems a bit buggy to me (having worked in IT & networking 30 years)
Do you configure the door sensor in the Aqara Home APP? Your screen looks strange to me, sorry.
The very first thing I tried long before coming here was the exact way shown in your screenshots. It made zero difference, so I tried disabling all devices notifications, and that too made zero difference.
My apologies if I was not clear about that previously.
Welcome to the forum!
Auto-lock trying to fire while the door’s still open shouldn’t happen it should wait until the door registers closed. Sounds like a calibration issue, but you’ve already redone that a few times, so if it’s still doing it, that’s probably a bad door sensor, not a setting. I’d send this one to Aqara support at this point, recalibrating is the documented fix and it’s clearly not sticking for you.
Notifications - the global toggle and the per-device ones aren’t the same setting. Check the U200’s own device page, tap the gear, look for lock/unlock toggles specifically in there, separate from the one you already tried.
No, that is connected to my Homey Pro, over Zigbee through the official Aqara app on Homey.
But I don’t have any problems with the content sensor, it works perfectly fine, and it triggers automations faultlessly on my Homey Pro.
It’s the U200 lock that that has issues, which is paired to my Aqara Hub M3 (and Matter bridged to Homey Pro just for notifications, the only automation I have with the U200 is an Aqara Mini Switch also paired to the M3 hub for remote locking/unlocking… and that automation is entirely handled by the M3)
Since the separate door sensor is reliable, I would isolate the U200 status path before changing more settings. After one manual lock/unlock cycle, note whether Aqara Home, the M3, and Homey update in the same order and at roughly the same time. If Aqara Home is already stale, the lock/M3 path is the better suspect; if only Homey lags, test the Matter bridge path separately.
