Hello, passage mode no longer work on v85 firmware on u200 - do you plan to fix it?
Thank you very much for your feedback. Could you please clarify what you mean by Passage Mode no longer working?
Please note that Passage Mode will be disabled if the lock button on the keypad is pressed. Could you confirm whether you are unable to enable Passage Mode, or if it cannot remain in the unlocked state?
If possible, could you also provide a related video showing the issue? This would help us better understand and investigate the problem.
