Is it possible that the locked door position engages the deadbolt in the same way as when I turn the key myself—so that it extends the deadbolt—but when unlocking, it does not also retract the latch, only the deadbolt itself? I only have a door handle on both the inside and outside, so a knob to push down. At night, I want the deadbolt engaged, and in the morning I want to unlock it, but the door should still stay shut.
@ferry Thank you for bringing up this interesting question about the U200 smart lock. Unfortunately, the reference information available doesn’t specifically address the U200 model or the exact functionality you’re asking about concerning the independent operation of the deadbolt and latch.
Typically, smart locks are designed to extend and retract both the deadbolt and latch for secure locking and unlocking. However, if you are looking for a feature where only the deadbolt retracts while the latch remains engaged, it may depend on the specific design and settings of the lock.
I suggest checking the user manual of the U200 smart lock or experimenting with the lock settings in the Aqara Home app. It might also be helpful to reach out to the community or Aqara support for more detailed guidance.
Please feel free to share more insights or any findings you come across, as they could benefit others with similar queries!
Thanks for your comment. We will add open door (unlatch) and unlock (only deadbolt) automation to aqara in the future to solve your second situation. In the first case you just need to unavalable the pull spring function on and it should work.
Hello, great question. I have a similar problem. I have the door set to automatically lock in the evening and I want to set the door to automatically unlock at the morning, but my type of door automatically “opens the door” after unlocking and retract the latch in the door, and after extending the latch, it stays open… I would just need to unlock the door and leave the latch in the extended position. When do you think we can expecting this function?
Hi, Thanks for your message. Could you take a photo for us to understand what type of door lock you are using? In most case you can just unavaliable the Pull Spring feature in Aqara Home app, and the lock will only Unbolt without Unlatch (Open door).
What is the status on this?
Would this also be exposed to other ecosystems such as HomeKit and Home assistant?
Hi @KinseyCreateGoods
I’m from the Netherlands.
This is a much needed feature for EU door locks. Can I know when this feature will be released?
Actually it seems this feature is already supported in Matter Spec 1.2. Matter 1.2 Arrives with Nine New Device Types & - CSA-IOT
“locked” and “unlocked,” but also “unlatched” state is available in this spec onward.
See here. https://leconiot.com/matter/1.2/appclusters.html#_lockstate_attribute
Can I create a feature request somewhere for this? I also have a door without latch bolt handle from outside. So to open it from outside, I need to use the “pull spring feature” no matter what. But i want to unlock the door inside and not let the door open all the way and keep the latch bolt intact.
Any European doors do have a latch pulling lock and no door handle on the outside of the house or apartment.
It is necessary for the lock to be able to pull the latch, which the U200 does.
What is lacking is a separate function to only lock and unlock the deadbolt.
Support, don’t play dumb and hide behind specific “U200 version” shenanigans. Or reference to the manual.
This function is simply missing.
I can’t have a routine unlock my door in the morning, as this will also pull the latch and the door will spring open. And I cannot disable the “pull latch” function altogether as then I couldn’t enter the house without a key.
@sutter_stefan Totally get the use case you’re describing: on a lot of EU-style setups you need latch-pull to enter from outside, but you don’t want an “unlock” automation to also retract the latch and pop the door open.
On the U200, the latch-retract behavior is tied to the Pull Spring Feature: when it’s enabled, the latch (spring latch / “inclined tongue”) can remain retracted for a set time after unlocking, specifically to allow opening without touching the handle. This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. Original post link: not provided in the reference info you shared.
What I don’t see in the available reference info is any setting that cleanly separates “unlock deadbolt only” vs “unlock + retract latch” as two different actions. The guidance only points to enabling/disabling Pull Spring Feature, not to a separate “deadbolt-only unlock” mode. This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. Original post link: not provided in the reference info you shared.
If you want this behavior as a product capability (especially for morning routines), the best next step is to formally submit it as a feature request so it’s tracked with your exact lock/cylinder scenario:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket. Sorry for the inconvenience.
If you share what cylinder/mortise type you’re using and whether Pull Spring is enabled right now, folks here can also compare notes on whether any workaround exists with specific door hardware.
yet, you did not (now it’s July 2026).
Reason enough to switch brands
Adding my case here too. Same setup basically, ABUS Euro cylinder with no
outside handle, so Pull Spring isn’t optional for me, it’s the only way to
actually get in. Which means every unlock also pops the door open, no way
around it right now.
It’s been over a year since this got flagged as something you’d look into,
so figured it’s worth a bump rather than letting it quietly die in an old
thread. Also opened a support ticket referencing this if that helps get it
in front of the right people.
Not trying to pile on, just genuinely hoping this is still on the radar
somewhere. Even a quick “yes it’s coming” or “no, technical limitation”
would be appreciated at this point. Thanks!
I’ve been waiting for the function for years. She won’t come anymore. The U200 died for Aqara. They prefer to take care of new things.
