U300 Lock is Locked on Both Sides
I just installed my second U300 lever lock. I love the first one and decided to change out an aging Yale lock for another U300. After completing the installation, I went through the firmware update and once that finished the door became impossible to open — from either side. It’s as if the firmware upgrade disconnected the internals from the levers. It was working as anticipated before the software update. Any suggestions?
@nycjeff34 It sounds like you’re experiencing an issue with your U300 lever lock after the firmware update. Let’s try a few troubleshooting steps to resolve this:
  1. Firmware Update: Make sure that the firmware version is the latest. Sometimes, a complete update isn’t applied correctly, so it’s worth checking again.
  2. Restart the Lock: Try restarting the door lock. This can sometimes resolve issues that occur post-update.
  3. Physical Connections: Check if the connection lines on both panels are connected well. An issue during installation or a loose connection might cause the internal mechanism to not function properly.
  4. Power Check: Ensure that alkaline batteries are being used, as specified, and that they are properly installed.
  5. Reinstallation: If the above steps don’t work, it might be a case of incorrect installation. Reinstalling the lock could resolve the issue.
  6. External Power: Try connecting a power bank to see if the lock responds differently, which could hint at a power issue.
If these steps don’t solve your problem, it might be beneficial to reach out for more direct support. Please contact the Customer Service Team through the Aqara Home App (Profile > Help & Feedback > Customer Service) or by scanning the QR code:
. If you don’t have an Aqara Home account, you can click here to create a ticket. Hopefully, these steps help, and we’d love to hear back on how it goes!
