Right now - you can setup this lock to stay in passage mode for up to 24 hours. That’s not ideal. I have somebody who lives in my house that doesn’t like the door being locked then they are home, so it would be super helpful if passage mode could be a permanent toggle or at least be able to pick a start date/time and end date/time. A permanent toggle would be preferred because then I could just keep it in passage mode until they are no longer in the house and then just toggle it back.
@ryanwpowers Totally get where you’re coming from — having to re-enable passage mode every 24 hours when someone in your household prefers it unlocked is definitely a hassle. Your use case for a permanent toggle (or at least flexible start/end scheduling) makes a lot of sense for long-term housemates.
Just to share what’s currently possible: the U300 does let you disable passage mode in a few ways — pressing the physical button on the rear lock, using a scheduled time window, or turning it off via the Aqara Home app (or Matter) when needed. And you can enable it directly on the lock with fingerprint/password/NFC verification. But you’re right that the scheduling is capped at 24 hours, which doesn’t solve your situation.
Since this would be a meaningful improvement for household flexibility, I’d recommend submitting this as a feature request through official channels. The team collects user feedback that way, though I can’t promise automatic prioritization for product updates.
For now, the quickest path to get this on record: Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
If you don’t have an Aqara Home account, click here to create a ticket.
Appreciate you sharing this — real-world usage scenarios like yours help shape what matters most.
