Not sure what’s up with these generic AI Bot responses. I actually received excellent response from Aqara team:
The Matter Auto-Lock and Aqara Home “Auto-Lock on Close” features use different triggering conditions and are configured independently. They are not settings where one takes precedence over the other.
1. Matter Auto-Lock
The Matter Auto-Lock setting is synchronized across Matter ecosystems, such as Apple Home, Home Assistant, and other Matter-compatible ecosystems.
It is a time-based, unconditional auto-lock function.
For example, if Matter Auto-Lock is set to 10 minutes, the lock will automatically lock when the 10-minute countdown expires, regardless of whether the door is currently open or closed.
2. Aqara Home “Auto-Lock on Close”
The Auto-Lock on Close setting in Aqara Home works differently.
It uses the lock’s gyroscope/door-position detection to detect whether the door has been closed. The lock will automatically lock after the door is detected as closed, according to the configured delay.
Therefore, this feature is condition-based, rather than an unconditional timer.
3. Can both settings be enabled at the same time?
Yes. Both settings can coexist and operate independently.
The two settings configure different auto-lock behaviors, and their configured time periods are also independent of each other.
Therefore, it is not a matter of “which setting takes precedence.” Instead, both auto-lock mechanisms can be active simultaneously, and each will operate according to its own trigger condition.
Example
Suppose:
- Matter Auto-Lock = 10 minutes
- Aqara Home Auto-Lock on Close = 1 minute
If the door remains open, the Aqara Home setting will not trigger because the lock has not detected the door as closed. However, the Matter Auto-Lock timer will continue running and can trigger after 10 minutes.
If the door is closed, the Aqara Home Auto-Lock on Close function can trigger according to its configured delay.
Sincerely,
Isabel
Aqara Technical Support
