Does the U400 smart lock have the Passage Mode feature like the U100? I can’t seem to find it anywhere.
@craig_s_davenport Hey there! Good news — the U400 does support Passage Mode, though it’s labeled a bit differently in some contexts. Based on the reference info, the U400 has a “Normally open mode” listed as a native supported feature when connected via Bluetooth, which functions similarly to Passage Mode on other Aqara locks.
For the U400 specifically, you can toggle this via the Action button — long press for 3 seconds to enable/disable the Auto-Lock on Close feature, which effectively gives you that passage-style behavior. There’s also mention of “Normally open mode (TBD)” in the Bluetooth feature list, so the exact implementation may still be evolving.
If you’re not seeing it in your Aqara Home app, make sure your lock firmware is up to date, as this feature appears to still be rolling out or labeled differently across regions.
Hope that helps! Feel free to share if you get it working or run into any quirks — always curious how these features play out in real-world use.
