U600 issue with it not actually locking
I received the U600 smartlock today and was excited to get it installed.
Sadly that excitement disappeared once I tried to add it to the Aqara app. I managed to add it first time but when I tried to change any settings, like auto lock settings, I would get a popup saying bluetooth not connected.
When I went back to the main screen for the lock, the little bluetooth icon was flashing and when I pressed it, it said bluetooth connecting. It never connected.
I deleted the lock and reset it to start again. The issue persisted but I did finally get bluetooth working and was able to get into the settings. I did however have to leave out connecting it to the M3 hub for this to work.
If I then tried to connect the hub, it would fail every time.
I deleted the lock again and tried to add it like the first time and it would simply not connect at all. Just kept saying “bluetooth not connected” when I was trying to add it to the hub.
What I also noticed is that even when the handle was locked, the door could still be opened from outside which is a serious issue. The handle made the mechanical noise when locking to suggest something was happening inside it but it did nothing.
I spoke to Aqara and ultimately got nowhere so have to send it back for testing and then once they have more stock, they will send a replacement.
A bit worrying that this can happen. What if it decides to fail like this once it has been working fine and someone can just walk into your house.
One of my curtain drivers has gone offline so i have tried to add it back to the M3 hub but it fails every time. I then tried to bind it to my G3 camera hub and it worked fine.
Anyone else had an issue with binding to the M3, all of a sudden?
Hi. My recommendation is to check the power supply for the M3; see if the power output is too low for it.
Hi, thank you very much for sharing your experience. We sincerely apologise for the inconvenience this has caused.
Regarding the Bluetooth connection issue, it may be caused by a damaged connection cable, poor contact, or an unstable connection.
As for the locking issue, under normal circumstances, the U600 should not allow the door to be opened directly using the exterior handle when it is locked.
Based on your description, we suspect this may be related to the installation. Specifically, the exterior handle may not be properly aligned with the arrow marking on the spindle mechanism.
If possible, could you please try removing the exterior lock assembly and checking whether the arrow markings on the handle and spindle are aligned, as shown in the image?
If they are misaligned, please try adjusting them so that both arrows point in the same direction, then check whether the lock functions normally.
We recommend testing this with the door open first. Please make sure the exterior handle cannot open the lock when it is in the locked state before resuming normal use.
We hope the replacement lock will fully resolve the issues you’ve experienced. If you encounter any further problems, please feel free to contact me directly or share your feedback. We’ll be happy to continue investigating and help you resolve them.
Thank you again for your patience and understanding!
I would agree that this is likely the issue. I had this happen to me during my installation and I had to recheck it. One I aligned correctly it then worked.
I have installed u600 yesterday
Install is quite easy, I came across a problem with resting the lock. I’ve initially tried to connect to my old hub and realised that isn’t hub matter so I could expose it to HomeKit (had it for few years)
I’ve added m3 hub and install again. It is visible in HomeKit added keys etc. But Aqara app can’t add it thru Aqara barcode is only paired via matter what I need to do to the reset lock and a pair in Aqara app again.
It was definitely pointing the correct way. This isn’t my first smart handle so know about this potential issue.
It’s gone back and I’m waiting for a replacement so fingers crossed.
It appears Aqara have done a good job and rectified the problem for you which is good to hear. Good luck.
