An Aqara Team reply says lifting the handle does not change the U600’s locked or unlocked status. That suggests a ‘locked’ status alone cannot confirm that a lift-to-lock door’s multipoint mechanism is engaged. A recent owner review raises the same practical concern about auto-locking without lifting the handle.
Could Aqara document exactly what the status in Aqara Home and Apple Home represents, and whether the hardware can detect handle or multipoint engagement separately? If it cannot, an in-app explanation would help owners avoid treating an automation’s ‘locked’ result as proof that the whole door is secured. Owners with the U600: what do you check before trusting the remote status?
@jamesfengyuyang You seem to be experiencing an issue with U600 lock status clarity and multipoint engagement detection. You can contact customer support for assistance.
This will be more efficient. If you do not have an Aqara Home account, “Please
click here” to create a ticket. We apologize for any inconvenience caused.
The way that the U600 works is by engaging and disengaging the exterior handle from physically being pushed down. I’ve not taken it apart to see exactly how, but basically a locked status means that the exterior handle is physically disconnected from rotating the spindle to open the latch bolt.
You can however, still pull the handle upwards to rotate the spindle and engage the multipoint manually.
So in terms of a lock status, the U600 considers itself “locked” when the hands is disconnected, but it doesn’t have any bearing not he status of the multipoint. You still have to manually engage the multipoint for the added security and the U600 does not know whether you have or not. I don’t see a way Aqara could do this any differently without adding more mechanisms to the door, many of which you can already buy and add on yourself.
I am thinking of it almost as two layers of security. If I close the door and forgot to engage the multipoint, then someone can not open the door with the handle alone. The only difference is the door would be physically less secure if they attempted to brute force the door open.
That mechanical distinction answers the question I was getting at. If the U600 cannot sense whether the multipoint is engaged, the app and documentation should describe “locked” as the exterior handle being disengaged, so it isn’t mistaken for confirmation that the door’s multipoint hardware has been lifted.
Aqara’s U600 product manager has now clarified that the lock does not lift the handle or engage the multipoint locking points automatically, and that its electronically locked state should not be confused with full multipoint engagement: A Message from the Aqara U600 Product Manager: Addressing Your Questions and Feedback. That confirms the distinction raised here. I still haven’t found an official statement that the app can detect whether the handle was lifted, so I would not treat a remote ‘locked’ status as proof of multipoint engagement.
For all intents, a door is locked when it’s not possible to gain access without using a key or some sort of authentication. Even without multipoint engaged, I would still personally consider the door locked, just not fully secured. Nobody can gain access still. The multipoint is only there as additional protection from forced entry.
